Hello!
I want to use the NI USB-6009 device for continously acquiring digital triggered (PFIO0) analog input samples (like an oscilloscope) using Labview 8.2 (Linux version) and daqmxbase. I have written a VI which basically works fine, but a small message window "Resetting VI: USB-92xx Bulk Reader.vi:1" sporadically appears (~1/sec) for a very short time (<0,5sec) in my left upper monitor corner.
The VI creates a task and starts acquiring a finite amount of samples from analog input triggered by PFIO0 (digital). In order to start a new acquisition, I have to stop and restart the task. This seems to cause the window flickering, which steals the input focus and prevents entering data into the UI. Is there a way to turn this off? Or a different way to code this vi?
(I have attached a screenshot of a test vi)
-Christian-
