Multifunction DAQ
Digital waveform generation with DAQCard-6036E
Is it possible generate digital waveform (via one DIO line) 10 kHz with DAQCard-6036E? If not. What card you can recommend?
Deniss Karai
(2,967 Views)
Deniss,
No, you cannot perform hardware-timed digital output through any of the DIO lines. However, you can generate a continuous pulse train at 10 kHz using one of the 6036's counter/timers, and the output will be TTL-logic compatible. If this will work for you, you can find shipping examples for generating pulse trains with the counter/timers.
-Kevin P.
(2,956 Views)
