Hello everybody,
I have a little question that seems to be simple, but I'm not sure whether my solution is right or not.
I wonder how to generate three separate digital signals using USB 6009 multifunction data aquisition card.
I've just prepared these signals as U8 samples and the value of each sample depends on which output line I want to use: For example if I want to generate digital signal on port P1 and on the line number 3 the value of each sample, that I treat as logical 1, is 00001000 this means that generatre array that contains as many numbers of value 8 as many samples I want to generate.
I have three separate signals prepared like that and I want them to be generated on separate, user defined digital lines in USB 6009 DAQ.
My guestion is whether my solution is good or not and if I can create three separate tasks using DAQmx Base as a base to genarate my signals on digital lines that I've choosen before.
If I would have to create single digital output task how to split these signals and generate them in the way I want to?
P.S My signals must be generated simultaneously
Any help will be helpfull
Many regards
Johnnie
