Digital input by DAQmx synchronized with other program
I have a program with analog input, I want to add digital input also in the program which I getfrom light sensors. kindly help me to get digital input continuosly and I want the number of samples equal to that by analog input. Which is at 50 Hz. Please help Thanks
(2,759 Views)
Hi rahulsongra,
What hardware are you using?  What version of DAQmx are you using? Are you using LabVIEW to program?  One example you should take a look at is Multi-Funtion-Synch AI-Read Dig Chan.vi.  You can find this example in the Example Finder located at Help>>Find Examples.  When the Example Finder opens double click Hardware Input and Output>>DAQmx>>Synchronization>>Mult-Function>> Multi-Funtion-Synch AI-Read Dig Chan.vi.  This example will synchronize a digital input with an analog input task.
Jim Schwartz
(2,740 Views)
