06-19-2007 04:33 PM
06-20-2007 11:00 AM - edited 06-20-2007 11:00 AM
Message Edited by Jesse O on 06-20-2007 11:00 AM
06-20-2007 03:56 PM
06-21-2007 10:53 AM
06-21-2007 11:01 AM
06-22-2007 01:33 PM
07-21-2010 09:41 AM
I've a strange error when I try to connect to the pxi-6521 board inside PXI-8104. The following error occurs in Measurement&Automation Explorer :
Error -63044 (kRIOStatusRioRpcServerMissing):
The RIO server could not be found on the specified remote device. Ensure that NI-RIO software is installed and that the RIO server is running and properly configured.
For NI-RIO 2.3 and later, refer to Software>>NI-RIO>>NI-RIO Settings under the system in MAX.
Prior to NI-RIO 2.3, refer to Software>>NI-VISA>>VISA Options under the system in MAX.
I've no problem to reach the other boards (RS-485) What am I missing ?
Thanks in advance
07-23-2010 06:37 AM
Hi Feno,
Can you please elaborate exactly when this error occurs, are you using a Task, Test Panels, opening MAX, etc? Does this happen everytime you perform this action? Is this an RT controller? If not, then what OS is used? Do you have the NI-RIO driver installed? What version of DAQmx? Is this a new behavior? What changed to cause this to begin happening? I apologize for the barrage of questions but these will help me get a better idea of the issue.
