From 02:00 AM CST Saturday, February 4 - 06:00 AM CST Saturday, February 4, ni.com will undergo system upgrades that may result in temporary service interruption.
12-07-2005 03:12 AM
12-07-2005 09:15 AM
12-07-2005 07:40 PM
Hi AnalogKid:
Thanks for your replying. You said current flows through the lump sum parameter RIN nodes (1) and (2) regardless if VS- terminal 0 is connected to ground or not.
Then what is Rin? Rin is the resistor inside the 6250 board or the bias resistors from AI- to ground? Could you please tell me?
Attached is my graph. I take VS as the voltage across 100ohm resistor. Is that correct? I would like to verify with you.
12-08-2005 08:49 AM
12-09-2005 03:58 AM
Hi AnalogKid:
Attached is my graph. How does current flow at the point where bias resistor started? Could you please tell me?
12-09-2005 07:49 AM
12-09-2005 07:49 AM
12-09-2005 07:02 PM
12-10-2005 01:33 AM
Hi:
I would also like to ask the AI+ and AI-. input. I might ask before, but I forgot. The AI+ and AI- input can only measure AC and DC voltage, am I correct? no current.
12-12-2005 08:14 AM
Your schematic is incomplete, you do not show a connection to anything on the bottom side of the bias resistor.
Correct, inputs will only measure voltage directly.
