If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Multifunction DAQ
Different Sampling rates on USB-6218
I understood that the USB-6218 has two seperate AI ports and therefore I can have a different sampling rate on each port? Is this correct?
If yes, how can I use this in the DAQ Assistant?
Cheers,
Dan
Message 1 of 8
(4,214 Views)
The USB-6218 has direct screw terminal connectivity. Each connectors provides access to AI, AO, DI and DO channels but: The USB-6218 has only one A/D converter, so every available AI channel is multiplexed to the same ADC and you've the option to set only one sampling rate for all AI channels, although it can be that the AI channels are on different screw connectors.
Hope that helps.
Luca
Luca
Message 2 of 8
(4,211 Views)
Thanks Luca,
That helps. But doesn't help my current project!! Can you tell me if the USB-6251 has more than A/D converter?
Cheers,
Dan
Message 3 of 8
(4,207 Views)
No, it doesn't. Maybe if you explained what your project is exactly, and why you can't use a single A/D converter clock. There are things you can do to make it seem one channel is acquired at a different rate. Simply discarding extra samples in one channel is one option.
Message 4 of 8
(4,202 Views)
I have 6 Channels that I need to sample at 10kHz and 8 Channels that only need samping at 1Hz.
If I sample all 14 channels at high speed I think i am going to running out of speed on the system. So would like to keep the high speed channels to a minimum.
I have read other posts about using decimation to throw away unwanted samples, but I assume this still gives the overhead in the hardware?
Thanks.
Daniel
Message 5 of 8
(4,198 Views)
You should have no problem maintaining a 10 Khz sample rate on 14 channels with either the 6218 or the 6251. Especially with the 6251, that's well within the specs. Your effective sample rate per channel is the sample rate divided by the number of channels.
Message 6 of 8
(4,195 Views)
OK, I see your point. think I had miscalculated that one somewhere.
What is the best way for me to discard the extra data for the 1Hz channels?
I am using the DAQ assistant. So should I just put the 1Hz analysis code inside a 1Hz timed loop?
Or is there a better way to sort the Dynamic data output?
Thanks again.
Daniel
Message 7 of 8
(4,188 Views)
I don't use the DAQ Assistant or dynamic data but with waveform data types, I'll usually just take the mean of the oversampled signal.
Message 8 of 8
(4,183 Views)
