Multifunction DAQ
Difference in source ground between NI DAQpad6015(BNC) and NI USB-6210
I am trying to read a wheatstone sensor module (http://www.dowaytech.com/en/2045.html) using the DAQ analog input ports. I am just using the DAQ assistant in the vi. I tried this task on two different DAQ hardware- the DAQpad6105(BNC) and the NI USB6210. I have a problem when I switch from the DAQpad6015 to the NI USB6210. On the DAQpad, the connections I did were, V+ and V- is connected to the AI0 in differential mode. Since I also need a start trigger, I connect the clock signals which trigger my measurements to the port named as PFI0/AI start trigger. And this works fine for me, I get a decent low noise signal. When I replicate the exact same connections, there is a lot more noise in the signals that are read. I am at a loss to understand why this is the case. Is it something to do with the grounding in the two scenarios? On the DAQpad, I can see a symbold of "Ground Ref Source", but there is no mention of this in the NI USB6210. Any help would be greatly appreciated.
Best Regards,
OOI
(1,912 Views)
Accepted by topic author outofideas
In the above line I mean that when I replicate the exact same connections *on the NI USB6210*. I am sorry it was ambiguous when I posted the question.
Thanks.
(1,892 Views)
