Multifunction DAQ
Difference between SCB-68 box and breaking out manually
Hi Guys,
Just wanted to know whats the difference between using
- SCB-68 break out box for my PXIe 6341
- Identifying the pins of the SH68 (is it possible ?)  connector cable and breaking out manually ?
Thanks in advance!
regards,
Joel
(3,987 Views)
Accepted by topic author joelkaka
Hi Joel,
The main difference is that SCB-68, or any other cabling accessories from NI, gives you easy I/O cabling and guaranteed specifications (e.g. EMC, safety). Breaking out manually is useful when you need to customize your cabling to meet your specific requirements. There a few things you should be aware of when breaking out manually, and these are explained in the manual of PXIe-6341 (page 2-7).
More information about the SHC68-68-EPM is available here.
Hope this helps.
Yodha
NI Singapore
(3,954 Views)
Thanks Yodha...
(3,906 Views)
