08-22-2007 07:41 AM
08-22-2007 07:49 AM
A major difference is that the USB 6008 is a piece of hardware and DAQmx is software.
The USB 6008 is a low cost data acquisition device. DAQmx is a driver for NI data acquisition devices and support for the USB 6008 is included in the driver.
08-22-2007 08:06 AM
Thanks for your fast response.
Then what is the meant for "NI USB 6008 does not have NI-DAQmx simulated device capability"?
08-22-2007 08:58 AM
08-07-2009 03:50 PM
I hope I can use this thread to ask some more questions about 6008 and its simulation in MAX.
I am going to simulate that device - mainly for Digital Inputs - can someone give me a hint where to look for the "ideal" device which can be used instead of 6008 ?
Regards
PacHOOk
08-10-2009 07:18 AM
Off hand, I can't think of a model but any of the DAQ or DIO modules that have bit level control (vs byte wide only) should due. I mentioned the DIO modules because you had said you are only looking to use the digital portion of the 6009. That's the nice thing about DAQmx, the software interface is the same for a $150 DAQ or a $5000 DAQ.
Tom
