Multifunction DAQ
Difference Between USB-6218 Multifunction I/O Device and Compact DAQ
Hello Everyone,
As I am amateur in the DAQ systems, what are the differences between a USB-6218 Multifunction I/O Device and Compact DAQ?
For what kind of applications are both? Can the USB-6218 Multifunction I/O Device control for example a motor from LabView?
Thank you
(2,255 Views)
The CompactDAQ platform is generally more robust, and has modular functionality which the USB-6218 does not. You need a counter output for pwm motor control, which the USB-6218 does have.
Conner A.
Technical Support Engineer
(2,222 Views)
