Multifunction DAQ
Device detected driver not loading correctly per windows
Device detected but driver not loading correctly. Windows says to reload driver. I have reloaded driver and the Nidaq software package (ver 6.9.3) repeatedly to no avail.
Upgrading from old machine that had a 1997 version of driver that work fine under this OS (win98SE).
What could be the problem?
(2,504 Views)
It's possible the copy of the NI-DAQ driver you have is corrupt, you may want to download it again.  It's available from the Drivers and Updates page.  Also, if you did not already do so, remove the DAQ card before uninstalling the driver and then reinstall it before reinserting the DAQ device.
What DAQ device are you using?  Depending on what DAQ device you have, you may want to upgrade the driver, the most recent version of the NI-DAQ driver for Windows 98 is 7.1.  You can see what driver is best for your device from the DAQ Acquisition Installer/Configuration Troubleshooter and then download the driver from the Drivers and Updates page.
Let me know if this doesn't solve your problem!
Micaela
Micaela N
(2,488 Views)
