I have a PCI-6014 board, and I would like to use the digital port to generate separate TTL pulses to trigger two different devices simultaneously.
I want the TTL to stay "high" for 3 seconds so I put the Write vi in a loop.
I initially had the port write a 1-D boolean (using two lines), but I discovered that one device (a solenoid) takes about 50ms to charge up, resulting in a lapse between the two devices by 50ms in the beginning and at the end as well.
Thus I have created two separate tasks and give one line a 50ms wait time before it writes. However it doesn't solve the problem.
I am guessing is it because both lines are from the same Port so that I can not generate a delay between them ?
My PCI-6014 board only has Port0.
I am also using both counters on the board so I can't use them.
Thank you very much in advance.
Joyce
