03-02-2017 04:26 PM
Hello, guys. I am facing some problems when trying to create a VI for data acquisition and controlling a relay.
I want to measure the voltage of a battery during charge and discharge. During the discharge, when the voltage falls to a specific value, a single pulse from a counter turns on a relay that inverts the polarization and starts the charge. This pulse lasts all the charge. When the pulse ends, a new discharge begins. The problem is that while the pulse is being applied, the measurement does not work, but when the discharge starts again, data acquisition works fine. I have tried continuous samples, N samples and so on, but nothing worked. I am a beginner on LabView so any advice will be great. Block diagram and VI files are attached.
03-02-2017 06:11 PM
Instead of a counter, use a standard digital output. I am pretty sure the counter task must finish before the loop will iterate. If going the DIO route, use the Elasped Time function to decide the state of you DIO.
