01-03-2017 08:14 AM
Hello friends,
I have a task of acquiring continuous samples from two C series-NI9215 cards mounted on cDAQ-9171. The technique available on
does not include for the case for C series. Can somebody please help me regarding this. It would have been better if the logic behind using these blocks is also exlained as I'm a beginner in data acquisition.
Thank you all in advance,
Gajanana Abhyankar B
01-03-2017 08:24 AM
Personally, I would just buy a cDAQ-9174, which is a 4 slot cDAQ chassis. Then you just create one DAQmx task with all of the channels and it is all taken care of for you.
01-03-2017 08:28 AM
I have a cDAQ-9184 chassis which is ethernet enabled. Is that OK if I mount the C series NI9215 on that chassis.
01-03-2017 09:06 AM
That would work as well.
01-04-2017 12:48 AM
Yeah, I mounted both NI9215 cards on cDAQ-9184, also added all 8 channels from both cards as a single task. But unable to synchronize. Is there a solution for this..?
