Multifunction DAQ
DaqMX 19.0 runtime ?
Highlighted
The Full DaqMX 19.0 SDK is available
http://www.ni.com/fr-fr/support/downloads/drivers/download.ni-daqmx.html#301173
But why is the "run time only" not available for download ?
Message 1 of 25
(1,741 Views)
Highlighted
He's on the way.
you can still work with runtime 18
Message 2 of 25
(1,708 Views)
Highlighted
Ok, I in that case I just find it surprising that SDK and client run time are not released together.
By curiosity, can you explain why ?
Message 3 of 25
(1,706 Views)
Highlighted
Sorry I'm not from the R&D so I don't have more information.
Message 4 of 25
(1,703 Views)
Highlighted
DAQmx 19.1 is out, but still no download options for the runtime or runtime with config support options. Are these still on the way?
Also is it possible to install older DAQmx runtimes (not full installs) with NIPM? I can't seem to find an option anywhere.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 5 of 25
(1,582 Views)
Highlighted
Same question, the runtime is really needed to deploy to client machines !
Message 6 of 25
(1,580 Views)
Highlighted
It seems the solution is to select the full DAQmx driver in NIPM, begin installing it, then deselect everything from the additional package list to install only the DAQmx runtime (how intuitive). It still wants to install the NI-DAQmx package (plus a whole heap of others) in addition to NI-DAQmx Runtime, so I'm not convinced it's the runtime only.
The offline runtime installer solution is basically 'build your own'.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z00000159txSAA&l=en-US
Message 7 of 25
(1,563 Views)
Highlighted
This is still not acceptable since client machines might not be connected to the network.
Message 8 of 25
(1,552 Views)
Highlighted
And of course, copying a ~3.5GB offline installer on each client machine is kind of less handy than the ~250MB run-time setup.
Message 9 of 25
(1,548 Views)
Highlighted
RunTime 19.5 is out, still no run-time deployment since 19.0
Message 10 of 25
(1,289 Views)
