DO(16x) + AO(2x) ELVIS II sampling help DAQmx 200621
I need to achieve continuous generation of signals about frequency from 1 to 200 Hz. The DO will goes to DAC and on the output became as analog signal on the same frequency. For convert to analog I use resistor-ladder. DAC working good as separated Vi. I tested AO single and double on one Vi. The problem is following:
I use DAQmx palette. But after generating I gets error 200621 (buffer underflow).
Is there method to achieve number of samples which cant give me signal with suitable smooth signal?
In the other sight isn´t that synchronization related problem?
For synchronization of 16 DO I use SW-timed synchronization.
For synchronization of 2 AO I use Continuous non-regeneration synchronization.
Any tips?
Thank you.
- Cuprum
(1,986 Views)
Have you tried running basic example Vis on your system?
Could you please share the code you are trying to run?
(1,919 Views)
yes I tried examples from Help > Find examples >HW input and output > DAQmx.
Did not find any solution.
This error still occurs by one time from ten random deploy of code.
My specs of laptop: processor i7-7700HQ, 16 GB DDR4 ram, nvme 256 GB Samsung storage
The code is in attachment.
Kind Regards, Cuprum
(1,910 Views)
Remove the 1000 msec wait from the loop.  That should make the buffer underflow error go away.   Once the loop iterates rapidly a few times at startup to fill the buffers, DAQmx will do the waiting for you.  Since you're writing 1 sec worth of data per loop, you'll eventually settle into a 1 sec per iteration loop rate.
You're writing a multi-sample digital waveform to an unbuffered, software-timed DO task.  I don't think your device supports hardware-timing for DO, so you should be writing just 1 DO sample (that can contain values for all 16 lines).  I don't know what you'll get when you try to write a multi-sample waveform to a 1-sample-at-a-time task.
Then you have the problem of sync.  Or rather, the lack of sync.  And the basic impossibility of sync with that device.  You're writing AO data to a buffer.  There will be some latency delay as the data works through the task buffer and the device's own hardware buffer before it becomes a real world signal.  Meanwhile, you'll have to write to DO with software timing where there will be no buffer and much less latency.  And you'll only generate 1 DO state for every 1000 AO states.  And that's just an average -- you won't actually have enough timing control for that 1 DO state to occur *exactly* every 1000 AO states.
In an earlier thread you were using a 6259 device.  *That* one at least is capable of buffered DO and hardware-driven sync.  It's a little indirect though as you'll need to understand and use "correlated DIO".   Basically, the DO task will need to borrow its sample clock from the AO task.
-Kevin P
(1,903 Views)
Dear Kevin Advice,
thank you for your reply which opened my eyes.
Now I got seriously problems with my digital output timing.
The project is cardiac pacemaker impulse tester. Those impulses will be reference for waveform located on the inside of heart muscles.
I need three analog outputs, based on three locations inside of heart.
Elvis II its not capable to gives three analog outputs, so I decided to bring third one by using 16x DO for
resistor ladder digital to analog convertor.
I used to generate that impulses by triangle pattern, with timing for analog outputs it works very good. I can set delay, amplitude, frequency & number of samples.
But for digital outputs, it doesnt works very well. It does not sync the impulses itself. Minimum DO I can use is 8x DO.
I sending here output on oscilloscope. The offset is not at zero (I am using differential amplifier for correcting this).
I tried to set DAQmx write (Digital > Single Channel > Multiple samples > 1D U32), there is difference that I am not using Analog to Digital vi.
Is there solution for this? Thank you.
(1,847 Views)
I've never used any NI ELVIS hardware, but over in this thread, you seem to have confirmed that DIO can only be software-timed by marking that response as your solution.
That being the case, I don't think this particular device is capable of letting you accomplish what you want.
As I stated before, there are 2 buffers worth of latency in the AO task where sample timing is governed by a hardware clock, largely independent of your loop iteration rate.  The DO task will have to be based on software timing where you can generate 1 sample per call to DAQmx Write, and sample timing depends almost *entirely* on loop iteration rate.
You're just not going to be able to get reliable sync this way.  You need a more capable DAQ device.  You certainly should not be expected to run tests on something as important as a pacemaker without also being equipped with a more suitable DAQ device.
There isn't a lot of point trying to give you small incremental help b/c it's all heading toward a dead end.
-Kevin P
(1,840 Views)
