With some external circuitry, you sure can. You will need some kind of current shunt resistor (something really small, such as 0.01 to 1 Ohm). I would also get a high-side current sense amplifier (such as a TSC103IPT) to turn the measurement into a single ended signal and into a voltage range more suitable for the DAQ.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
