08-08-2006 10:40 AM
08-09-2006 03:50 AM
08-09-2006 05:52 AM
Hi Stuart,
I think Iv'e managed to fix it. The problem seemed to be related to the individual Current "create virtual channel" sections. I deleted all the individual tasked channels and used a control box on the "global virtual task" node of the "create DAQmx task". This allowed me to browse via the Assistant wizard to both the Current and TC channels, which I couldn't do using one "DAQmx Assistant" object.
In the original VI, the parameter values for the existing current virtual channel objects are the same as the settings that I have used with the wizard so I'm not sure what is wrong with them or why it used to work with our old Setup.
But the other method works, so all is good.
Thanks for your response though. If you have any thoughs please let me know for interest.
08-09-2006 06:02 AM
