Thanks Andrew,
It is right where you said it would be. Interestingly though, I have been looking at the exact same place and all I would see under DAQmx Base is: Read, Write, Start, Stop and Task Config/Ctrl. This is when I would open my VI through the project. If I open a blank VI, I see everything under DAQmx Base.
Do you know why this would happen?
vickie
