01-09-2006 03:52 AM
01-09-2006 11:19 AM
Benne,
I have a VI which I have written which will list both device names as well as their product types. You should be able to use something like this to associate the device names with the functionality you need. I have attached this VI.
Hope this points you in the right direction,
Dan
01-09-2006 12:38 PM
01-11-2006 04:05 AM
01-11-2006 10:18 AM
Benne,
Yes, unfortunantly I believe that these may be properties that are available in DAQmx, but not DAQmx base (I'm not an expert with DAQmx base). Are you working on a platform where DAQmx is not supported? If not, I would highly recommend that you use DAQmx.
Dan
01-11-2006 10:27 AM
01-11-2006 11:00 AM
Benne,
The VI should work whether the devices support simulation or not. It will basically list all device names found on your system, as well as their product type. If you are familiar with simulation, it is simply the ability to tell DAQmx that there are devices present which actually are not. Since these devices cannot be simulated, the VI will only work for these devices when the devices are connected to your computer. When they are connected , you should be able to search the array of device types ('Array') for the device you need, then look back at the DevNames array at the same index to determine which device name corresponds to the device you need.
I'm not sure I've understood your last question correctly. If I have not, please let me know, and I will do my best to answer your question.
Hope this helps,
Dan
01-11-2006 01:28 PM
01-11-2006 01:55 PM
01-11-2006 02:51 PM
