Multifunction DAQ
DAQmx is not member of NIDAQmxCAPI
I am using Visual Basic 2005 Express to configure and control the USB-6008. I have included a reference to the NIDAQmxCAPI into the VB project.
When I try to load the sample code for "Acq-Int Clk" for example, I get the following error:-
"DAQmx is not member of NIDAQmxCAPI"
Here is a snippet of the code that causes the problem but the same thing appears in other places as well
'Create the DAQmx task.
DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxCreateTask(
"", taskHandle))
(5,085 Views)
Jarra,
Thanks for contacting National Instruments.  I have opened this example in VB 6 since that is all we have here.  The line of code you speak of says:
    DAQmxErrChk DAQmxCreateTask("", taskHandle)
There is no reference to NIDAQmcCAPI in our documentation.  Visual Basic Express 2005 is used for developing VB .NET which is very different from the examples that we have written for VB 6.  Try using the .NET examples that came with the DAQmx driver.  Look in this folder.  C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\DAQmx\Analog In
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(5,069 Views)
Thanks Ken,
I think this has me on the right track now.
(5,056 Views)
Hi Keen,
I am facing the same problem when trying to convert code from Visual Basic 6.0 to Visual Studio 2008.  The code example I found is in:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage\Acq-Ext Clk
According to the example, I replaced the original code in Visual Basic 6.0:
DAQmxErrChk(NIDAQmxCAPI.DAQmx.DAQmxCreateTask("", taskHandle))
With
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
However, the code still does not work, saying the DAQmxCreateTask is not declared
I was wondering if you wound be willing to provide me some sugestions?
Thanks!
(4,228 Views)
bwang,
Are you able to run the example code without any problem? Can you post your code here so we can see what else might be going wrong?
J. Calvert
Applications Engineer
(4,213 Views)
Hi Kathryn,
Thank you for your help.
I am now converting VB6 to VS2012 instead.  The examples in
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.5
are useful!
Besides,
1. I changed target framework from â€˜.NET Framework 2.0’ to ‘.NET Framework 4.5’
2. I added "National Instruments Common" and "National Instruments DAQmx" as the references.
It works now.
(4,168 Views)
