DAQmx - error 50202
When configuring an AIVoltage on a PXIe-6358 using a polynomial scale of order 3, I get the following error:
Error #-200537 Property Node DAQmx Channel (arg 1) in AIGroup.lvclass:SetBuffer.vi:7370001->AIGroup.lvclass:SetPropperties.vi:1130001-
>Board.lvclass:CreateTask.vi:40002->DAQgn_Main.vi:7220001->GENERIC_Main.vi->Generic config.vi->Daqmx_Configure All tasks.vi->RT task.vi->Main.vi <append> <B>Property: </B>AI.Min <B>Requested Value: </B>-96.383560 <B>Possible Values: </B>-96.393560 to  90.025105 <B>Scale Name: </B>PXI1Slot5_PXI1Slot5_ai0_Scale  <B>Channel Name: </B>PXI1Slot5_ai0  <B>Task Name: </B>PXI1Slot5_A
scale = 0.522355377797965 + 10.0774426677173 * x - 0.0370658257511309 * x^2 - 0.00756509423297235 * x^3
elec range = -10 to 10
output range = -96.3835596415157 to 90.0151052468855
when using an output range = -96.2935596415157 to 89.9251052468855 it works
Please can someone explain what is the rule? or how can I bypass that issue?
(2,129 Views)
Looks like you have a floating point rounding issue.  Where are you coming up with the range you are putting into the DAQmx Create Virtual Channel?  Supplying some code would help the debugging process.
GCentral
(2,124 Views)
The rounding issue is not on my side, because the error message says: -96.383560 is not in the range -96.393560 to  90.025105, that is wrong.
An extract of the code is not possible because it's part of a very large S/W, and it would take a lot of time to build an usable and representative test program.
The solution we certainly will use is to leave the AI.Min and AI.Max properties unset.To be checked ASAP.
(2,112 Views)
