Hello Lampje,
Thanks for contacting National Instruments.
National Instruments has not yet released NI DAQmx Base Support for LabVIEW 8.5. Until it does release, you should be able to follow the instructions below to use your DAQ device with your MAC. This process assumes you have moved from LabVIEW 7.1 to 8.5. Users who are moving from LabVIEW 8.0 or more recent to LabVIEW 8.5, DAQmx Base 2.1 may be used instead of DAQmx Base 2.0.
1.) Install LabVIEW 7.1 AND LabVIEW 8.5
2.) Install NI-DAQmx Base 2.0 with support for LabVIEW 7.1 (DAQmx Base 2.1 only installs support for LabVIEW 8.2 and 8.0)
3.) Manually copy the following files and directories from the LabVIEW 7.1 directory to the LabVIEW 8.5 directory:
Please post back if you have any questions.
Browning G
FlexRIO R&D
