10-10-2005 01:59 AM
Hallo,
I'm running MAX 3.1 on a PXI with Windows XP. I have a PXI-6025 I/O card
plugged in. I have created two different tasks with DAQmx. Task A should
read in the ai0 port, task B should read in the ai1 port.
The thing is that when task A is started, I cannot start task B (neither in
MAX nor in LabVIEW), I'm getting an error like "Resource is used".
The same thing vice versa, only the task that has been launchd as first is
running properly, the second one returns an error when trying to start.
How can I create and run two tasks, that run on two different analog input
pins.
I have created a bunch of other tasks that ouput on digital pins, the're
all fine.
Thank you for your help
Oliver Friedrich
10-10-2005 03:46 AM
10-10-2005 11:36 AM
10-11-2005 02:28 AM
