Multifunction DAQ
DAQmx Digital Output task works with DAQmx Read
Can someone explain why this snippet works?
A digital output task is created and a DAQmx Read works with it, shouldn't the output task only work with DAQmx Write?
Thanks in advance
CLD
(2,639 Views)
Accepted by topic author ArAmM
Hi ArAmM,
It is intentional.  Here's a KB with a similar code snippet explaining that this is supported.  It works because the read is returning the current value being output--it does not change the line direction.  You are still driving the line(s) in your task.
(2,606 Views)
