Multifunction DAQ
DAQmx, C++, program onDemand output
HI,
I have a task configured to do buffered output (N samples, loaded from MAX)
now I want to reconfigure it to do single sample OnDemand output
DAQmxCheck((DAQmxStopTask)(task), "DAQmxStopTask:");
DAQmxCheck((DAQmxWriteAnalogScalarF64) (task, (bool32)_autoStart, (float64)_timeout,
_writeArray[0], NULL), "DAQmxWriteAnalogScalarF64 -- single --:");
Response:
Generation cannot be started, because the selected buffer size is too small. Increase the buffer size. Error -200609 (fffcf05f)
If I create OnDemand task in MAX everything os OK.
How to 'undo' output buffering ?   Win7-64+NI6002
Thanks!
Boris
(3,141 Views)
I am confused.
If you are creating a task in NI-MAX and using it, just create create the one that works and use it.
(3,123 Views)
Hi NYC,
I have a program that switches between outputing of a pattern (saw tooth) and single value (locking on some value)
I load task from max (which is a user friendly place to configure channels)
So at some point I want to stop pattern and send out just a value
To avoid locking of other board resources (like counters) I would just switch to ondemand mode now - but that does not work
Surely I can kill the task and recreate it in other mode but that is less convenient
Boris
(3,118 Views)
