Multifunction DAQ
DAQmx Base 3.5 in Lion resulted in mixed readings from Analog Input channels
I just installed DAQmx Base 3.5 on Lion for a NI USB-6211. When I run datalogger, the channels get mixed up. For example, voltages applied to ai 0 , ai 1, ai2 , affects ai3.
This does not happen on the previous drivers + Snow Leopard.
(2,527 Views)
Hi kalanyuz
Thanks for using NI Discussion Forums!
May I ask for more info about your setup?
When you say that the channels get mixed up, what exactly happens?(channels get switched, no voltage detected, etc.)
Does the same thing happen running a sample vi, or is it only with the datalogger?
Have you been using the USB-6211 with previous drivers?
Sorry to overwhelm you with questions but I'd appreciate if you could answer these questions.
Thank you,
Ryuji Kuwajima
National Instruments Japan
(2,498 Views)
