I am using ANSI C of NI DAQmx to develop my imaging acquisition software. The use of ANSI C is interfaced with PyDAQmx using Python language. The code is attached at the end of this message. By using DAQmxGetSysDevName and
class DAQInit():
def __init__(self,GalvoData,scanMode="2D",NumOfAscans=1024,LineScanRate=5000,XOffset=2,YOffset=2,GalvoRate=10000,swapAxis=0,PointsInEachWvm=1000000,deviceName="Dev2"😞
self.GalvoData = GalvoData
self.scanMode = scanMode
self.NumOfAscans = NumOfAscans
self.LineScanRate = LineScanRate
self.XOffset = XOffset
self.YOffset = YOffset
self.GalvoRate = GalvoRate
self.swapAxis = swapAxis
self.deviceName = deviceName.encode("utf-8")
self.AOphysicalChannel = "Dev2/ao0:3"
self.AOphysicalChannelClkSoure = "/Dev2/PFI12"
self.PointsInEachWvm = PointsInEachWvm
self.AOphysicalChannelTriggerSource = "/Dev/PFI14"
self.CreateDevAO(self.GalvoData,self.AOphysicalChannel,self.AOphysicalChannelClkSoure,self.GalvoRate,self.PointsInEachWvm,self.AOphysicalChannelTriggerSource)
def CreateDevAO(self,Galvodata,physicalChannel,ClkSource,Rate,sampsPerChan,TriggerSource,limit = [-5,5]):
self.physicalChannel = physicalChannel
self.AOphysicalChannelGalvoData = Galvodata
self.AOphysicalChannelClkSoure = ClkSource.encode('utf-8')
self.AOClkRate = Rate
self.sampsPerChan = sampsPerChan
self.triggerSource = TriggerSource.encode('utf-8')
taskHandles = TaskHandle(0)
self.DevAOtaskHandles = []
self.ActualSampsPerChan = C.c_int32(0)
self.limit = limit
xt = 'e'
attr = C.create_string_buffer(xt.encode("utf-8"),64)
buffer = C.c_uint32(40)
try:
DAQmxCreateTask("Galvo_Control_Signal",C.byref(taskHandles))
print(taskHandles.value)
# create physical channel as Analog Output
DAQmxCreateAOVoltageChan(taskHandles,self.physicalChannel.encode("utf-8"),"",self.limit[0],self.limit[1],DAQmx_Val_Volts,None)
DAQmxGetSysDevNames(attr,buffer)
print("System Device Name(s): {}".format(attr.value))
# configure sample clock
DAQmxCfgSampClkTiming(taskHandles,self.AOphysicalChannelClkSoure,self.AOClkRate,DAQmx_Val_Rising, DAQmx_Val_FiniteSamps,self.sampsPerChan)
# start trigger of analog output write
DAQmxCfgDigEdgeStartTrig(taskHandles,self.triggerSource,DAQmx_Val_Rising)
# set trigger to be retriggerable
DAQmxSetStartTrigRetriggerable(taskHandles,True)
# write data into buffer of analog output channel
DAQmxWriteAnalogF64(taskHandles,self.sampsPerChan,True,0,DAQmx_Val_GroupByChannel,self.AOphysicalChannelGalvoData,C.byref(self.ActualSampsPerChan),None) # None is passed as c null pointer
except DAQError as err:
print("DAQmx Error: %s"%err)
finally:
if taskHandles:
# DAQmx Stop Code
DAQmxStopTask(taskHandles)
DAQmxClearTask(taskHandles)
self.DevAOtaskHandles = taskHandles
if __name__ == "__main__":
t = np.linspace(0,100,10000)
f = 1
y = 0.01*np.sin(2*np.pi*f*t)
d = np.asarray([y,-y,y*2,-y*2])
DAQInit_examp = DAQInit(GalvoData=d.astype(np.float64),PointsInEachWvm=np.size(t))
