DAQmx 9172/9477 modules lose PC connectivity
Have you tried updating the daqmx drivers? I am not sure why you are still having this problem. I had to deal with this for a while, but the USB setting seems to have reduced the likelihood, but not sure it has completely.
Also, IS your laptop (I am assuming you are using a Laptop), connected to a power source all the time?
I may not be perfect, but I'm all I got!
Message 31 of 40
(2,444 Views)
It's actually a desktop PC.
Message 32 of 40
(2,440 Views)
Oops!! Well, I am not sure what's going on. I do have this issue with NI to look into, but all I have been said so far is what I have shared with you. And what you posted is exactly what I have done. Now I am worried that my USB 6008 will start behaving sporadically.
Any NI Engineers have further details on this?
Message 33 of 40
(2,434 Views)
nooneshome,
I would recommend that you update your DAQmx driver to the newest version.  It should be compatible with your system.  I've included the link below:
NI-DAQmx 9.6
http://joule.ni.com/nidu/cds/view/p/id/3423/lang/en
Have you installed the hotfix for USB devices running on Windows XP?  This can be found at the link below:
Hotfix
http://support.microsoft.com/kb/969238
Jared R.
Precision DC Product Support Engineer
Message 34 of 40
(2,417 Views)
I will try both and let you know.   thanks for your support!
Message 35 of 40
(2,414 Views)
I have the same infuriating problem on my Dell PCs and on my Dell laptops here. For me, it seems to be an electrical noise issue.
I tried using a better USB cable with ferrites installed. I tried re-routing the usb cable. SO for, nothing works. Next, I plan to try a USB isolator.
I am really hesitant to use these on future designs.
Message 36 of 40
(2,341 Views)
I tried the USB isolator - not much help. I will next try opto-isolating the I/O.
The 9477 seems to be very sensitive to noise. I'm now having the same problem in another test system that uses the 9477.
That one has an electrical motor in the system.
Message 37 of 40
(2,290 Views)
Hi khalsans,
It looks like this thread has been inactive for a while, so you may find more success by opening a new forum thread. New threads are more likely to catch the attention of other users on this forum, and you'll have a better chance of receiving user input with your issue.
Also please make sure to post your DAQmx driver version and computer make, model, and operating system, as well what kind of noise you're receiving on the USB wire. Thanks!
Message 38 of 40
(2,270 Views)
The error occurs under every version of Labview I've thrown at it, so it's a harware problem.
It's not noise on the USB line, but noise on the digital lines that causes the problem.
I'm not sure what you mean by what kind of noise. I have a high voltage relay on on the system, the other system has a motor and pneumatic vavles .
My suspicion is that the digital lines are seeing signals bounce below ground and are latching up.
Message 39 of 40
(2,230 Views)
We finally solved the problem - the high voltage relay was coupling really nasty noise spikes into the DIO line. Once we isolated that, the USB did not lock up.
Message 40 of 40
(1,713 Views)
