06-28-2007 01:42 PM
06-29-2007 10:53 AM
Hi Tyler,
In order for the card to be found in Measurement and Automation Explorer (MAX), the card first needs to be found by the computer and have the correct drivers associated with it. How did you get MAX 4.2.1? Did you Install LabVIEW? Install Traditional DAQ?
Is your device found in windows Device Manager? If so, is it under ‘Data Acquisition Devices’ (Indicating the correct drivers were installed and found) or under ‘System Devices’ (probably having a yellow circle with an exclamation point by it)? If it is under system devices, right-click on the driver and say ‘update driver’ and let windows automatically find the correct driver.
Once the card is found under Data Acquisition Devices, it will be found in MAX. If it is not, then please see this Knowledgebase .
