Multifunction DAQ
DAQPad-6016 with labview 5.1
I have general question question:
Is it possible to use the DAQPad 6016 with labwiew 5.1?
If so can I use an USB or COM port? And what would be needed to be configured?
Greetings
(3,902 Views)
i would like to know that too.
Greetings
(3,889 Views)
DAQPad-6016 is only supported by NI DAQmx Driver.
The oldest Version of DAQmx i was able to find is 7.4
This version supports only LabVIEW 7.X
This implicates that there is no Version of DAQmx that is compatible with LabVIEW 5.1
So this device wont work with LabVIEW 5.1 you will have to get a newer Version of LabVIEW
Best Regards!
Moritz M.
(3,881 Views)
Thank you
(3,873 Views)
Thank you
(3,860 Views)
