I try to configurate the DAQCard-700 on a Toshiba Tecra 8000 running WinNt4 (SP4).
The problem is that I am unable to find the right combination for the I/O address and the Interupt number. In the Ni-DAQ 6.6.0 software, the say that we have to try all combination possible. There is too much combination to try. Is there a trick to find the good combination for the address and the interupt ?
Benoit Petitclerc, P.E.
Sent via Deja.com http://www.deja.com/ Before you buy.
In article <7tvb7m$m5a$1@nnrp1.deja.com>, bpetitclerc@my-deja.com wrote: > I try to configurate the DAQCard-700 on a Toshiba > Tecra 8000 running WinNt4 (SP4)and a XIRCOM CEM56 Card. > > The problem is that as soon as the Xircom card is in the PC, the DAQCard-700 doesn't work. The software return and message that the device doesn't respond to the specified base address. Thes Xircom and National Cards have no conflict in the interupt number and base address configuration..
As soon as I remove the Xircom card from the Pc, the DAQCard works perfectly. > > Thanks > > Benoit Petitclerc, P.E. > > Sent via Deja.com http://www.deja.com/ > Before you buy. >
