06-28-2007 01:58 PM
06-28-2007 03:03 PM
06-29-2007 05:20 AM - edited 06-29-2007 05:20 AM
Whatever Windows OS you are using NI-DAQ 6.9.3 will be the latest driver supporting your board (from Win95-WinXP). This driver also contains the support for LabVIEW (if you use LabVIEW) from version 5 to 6.1. If you use a higher version of LabVIEW it will still work but then you have to do some copy work after installing the LabVIEW support.
Below you find the link to the webpage where you can download this driver. Be sure to download also the proper LV version support installer:
http://digital.ni.com/softlib.nsf/websearch/50F49E43A22C0D2186256BF3006B9A96?OpenDocument
If you use a higher version of LV then 6.1 just download the LV support file of the highest version and install that. After that follow the steps in the Knowledge Base linked below to copy the DAQ support to your LabVIEW version:
http://digital.ni.com/public.nsf/allkb/F185E098C7EC5A3486256D2E00691BB2?OpenDocument
Hope this helps,
RikP - National Instruments Applications Engineering
Message Edited by RikP on 06-29-2007 05:20 AM
