01-28-2019 04:41 PM
Hi Everyone,
I'm looking for a DAQ that is capable of simultaneously measuring at least 3 analog voltage input signals and outputting at least 3 analog current signals with a range of 0-20mA. Basically I'm inputting a voltage signal and I want the DAQ to output a current signal. I've searched high and low and cannot seem to find a model capable of this.
01-29-2019 09:19 AM
You will probably have to look at using a CompactDAQ chassis and getting a couple of C series modules for your I/O. I did find a PCI-6704 card, but it is only an output card (voltage and current).
Look here for modules:
Or try the advisor to build a system
Another option is to call your local rep and get recommendations.
Or look into buying/making a voltage to current converter. It looks like there are some PCI/PCIe cards that have 4 analog output channels that you could use. It will also depend on how much you have to sped on your system.
01-29-2019 09:37 AM
What form factor are you looking for? You could easily use a cDAQ to do 3 simultaneous AI channels and 3 current output channels. For voltage input, you could use the NI 9201 or 9215. For current output, you would use the NI 9265 or 9266. Any 4-slot cDAQ chassis would work, such as the cDAQ-9174, cDAQ-9184, or cDAQ-9185.
I believe the only PCI/PXI options that NI has for current output is the PCI- or PXI-6704 and the PXIe-4322, although these cards don't have any voltage input channels.
-Jordan
