Multifunction DAQ
DAQ using NI-6008 in LabVIEW
Dear All
          I m new here. I m using NI USB-6008 and acquiring analog signal on three of its input analog channels from different sensors. I want all these three readings to be displayed on three different numeric displays rather than to be shown on graph where all three signals are shown simoultanoeusly. The problem is that DAQ assistant is giving only a single multiplexed output ("Data") but I want all these three readings seperatly with different scalings. It is requeted to please guide me that how it can be achieved.
Please let me know if I can Provide you further information. A simple view is attached for calrification that want I need.
WASIF
(3,941 Views)
You didn't attach anything. If what you want to do is have three separate graphs, then just use the Split Signal function (Express>Signal manipulation palette). It can be dragged to provide as many outputs as you have channels. Just wire up the three individual graphs to them. If you are taking a single reading from each channel, you could also just use three separate numeric indicators.
Message Edited by Dennis Knutson on 11-02-2007 01:49 PM
(3,940 Views)
Thanks Dennis.
I done what I wanted.
(3,912 Views)
I am trying to install NI-DAQ for NI 9233 but it does not work. I have labview 8.0 and windows Vista. Labview 8 works good until now in this windows, so the problem is with windows, with labview?. I can not install the software NI-DAQ 8.5 or 8.6 because  appear this message:
Unsupported version of National Instruments system component detected
Unsupported version of NI-VISA detected
Unsupported version of NI PXI Platform Services detected
Unsupported version of NI-DAQmx detected
Does anybody know what can I do???????????????
(3,844 Views)
See reply to Rafo's question here.
Tom W
(3,835 Views)
