09-09-2009 07:05 PM - edited 09-09-2009 07:10 PM
I am using a USB-6009 in differential mode 14Bit resolution as shown in the code and frontpanel attachment. I am acquiring two channels,one is the photodiode voltage and the other one is a ramp reference signal which is also used to trigger the DAQ using the digital input.
The confusing results are shown in the attachment trigger+diodevoltage_zoom.jpg: There is the ramp / trigger signal in blue and the photo voltage in green.
Whilezooming in onto the green signal it is easy to see that the noise of >20mV is way bigger than the theoretically possible 0.3 mV resoluton referring to the 14 bits.We checked the same signal with a scope and got much better signal to noise ratio. We also tried a second USB-6009 and received the same bad results and another photo diode had almost the same noise.
Sounds like a trivial problem hundreds of times asked here, but still cannot figure out why the SNR is so bad.
Thanks for any help,
Erik
09-11-2009 02:56 AM
What I would try:
-A ferrite core (Choke) with 10+x windings of both wires (Ain AGND) from the diode to the input channel.The Analog INPUT of the ADCs are known to be noise sources.
Nice lit: http://ts.nist.gov/MeasurementServices/Calibrations/upload/72C-2.pdf
-Build a transimpedance amplifier to get a low impedance signal (I just played around with samples (upper right corner) from linears LTC 6240)
(takes 30min to build a dead bug bread board amp plus ?days to get the material 😉 )
