05-26-2013 06:56 AM
I have windows 7 enterprise, labview 8.0 and DAQmx-8.6.1 to run a DAQcard 6211. I couldn't install visual studios properly as it was dependant on the .net framework 1.1 which is not compatible with windows 7. What should I do to fix this problem?
P.S. I have reinstalled the device drivers and DAQmx several times.
This is the options I get in the MAX:
08-08-2013 06:37 PM
DAQmx 8.6.1 does not support Windows 7. It only supports up to Winodws Vista. The first DAQmx driver to support Windows 7 was DAQmx 9.0.2.
You could try installing DAQmx 9.0.2.
DAQmx 9.0.2
http://joule.ni.com/nidu/cds/view/p/id/1444/lang/en
LabVIEW 8.0 is not officially supported in Windows 7. Windows 7 was not officially supported until LV 2009 SP1 ( http://www.ni.com/white-paper/10356/en#toc1 ).
If installing 9.0.2 doesn't work, you'll either need to upgrade LabVIEW, or roll back to Windows XP (I don't recommend Vista).
08-12-2013 03:16 PM
Unfortunately though, DAQmx 9.0.2 doesn't support LabVIEW 8.0 according to here.
Best Regards,
