I am seeing this problem with 2 different DAQ cards. The card works fine with the NIDAQ test panel, but acts like the return lead is lifted with my VB app. The plotted signal appears to be little more than noise. Channel scan is internally triggered; that apparently works fine. The VB app is running in this configuration successfully in other areas, and I fixed this problem once by swapping cards. Currently, I lack a spare, as my "spare" is showing the same symptoms. Any helpful hints?
Card type: AT-AI-16XE-10
Configuration: Double-ended input, +/-10V range
Running: VB6, NIDAQ 6.1, ComponentWorks Std. 2.0.1, Windows NT 4.0 SP5
