DAQ assistant/ DAQMX task name issue
I have LabVIEW 2013. When I select a new DAQmx Task name and I right click -> New NI-DAQmx Task -> MAX... I get the 'Initializing' screen and after that LabVIEW freezes and I have to close it in the Task manager.
The same thing happens when I select the DAQ-assistant. The 'initializing' screen shows and after that it all freezes. I have the correct drivers installed and never had this problem in my previous LabVIEW version. (I recently switches to the 2013 version).
Can anyone help me with this? I could post screenshots if that can help.
(3,927 Views)
Dear Fatsat,
It sounds like during the installation of your software there has something go wrong and a component got corrupted. I have seen this issue once before and it was solved by repairing (or re-installing) the following two components:
NI System Configuration 5.5:
http://www.ni.com/download/ni-system-configuration-5.5/4086/en/
NI-DAQmx 9.8
http://www.ni.com/download/ni-daqmx-9.8/4297/en/
Could you try that and let me know if it solves you issue?
Rik Prins, CLA, CLED
Software Development Engineer
(3,906 Views)
