01-17-2008 04:27 AM
01-21-2008 03:11 AM
Hello Gizra,
normally this should work without a problem but it depends from some things like how you program it and so on.
Do you have troubles with it?
01-21-2008 03:26 AM
01-21-2008 03:56 AM
The easiest way for sharing data is to use the Realtime Communication Wizard. it is descirbed in the follwoing link:http://zone.ni.com/devzone/cda/tut/p/id/4676
I´ve also searched some more information material for you:
Real-time FIFO: http://zone.ni.com/devzone/cda/tut/p/id/3934
Shared Variables: http://zone.ni.com/devzone/cda/tut/p/id/4679
http://zone.ni.com/devzone/cda/tut/p/id/3898
Hope this helps,
01-21-2008 06:51 AM
