Multifunction DAQ
DAQ Event messaging in C++
I am about to develop a data acquisition application using PCI-3071E
and Microsoft Visual C++. Are there any sample code demonstrating
adding message events to the Window messaging queue. Most of the code
examples that I have found on the Ni.com website show inline coding.
John
(1,041 Views)
Hello John,
if you want to use asynchrone events, you must use the function Config_DAQ_Event_Message. You can receive events on window port or callback function.
I send you a small programm that I have made to demonstrate a bug under NI-DAQ 6.9.1 with Config_DAQ_Event_Message (bug is with external scan clock and multiple of x scan events, normally you never see it) and can be use with every DAQ-STC card.
Search in the code the first Config_DAQ_Event_Message and the comment //not used handle. In your application, change it to your window handle (change WM_USER to what you want) and in your window messaging queue, add ON_MESSAGE(WM_USER, OnDAQEvent) with afx_msg LRESULT YourWindow::OnDAQEvent(WPARAM w, LPARAM l).
See Config_DAQ_Event_Message for sig
nification of w, l parameters.
Hope this will help,
Grettings,
Alain
(1,041 Views)
