When I run DAQ Diagnostic Utility Version 2.0 it generate some fail in Analog Input and Analog Output.
Would you please help me?
7/20/2010 1:59:13 AM
Results saved to: C:\Documents and Settings\Mechatronic\Desktop\Diagnostic Results.txt
Selected Device: Dev2
Device Type: PCI-6259
Serial Number: 148E1D9
Device Support: (PASS)
NI-DAQmx Version: 9.0 (PASS)
Device Reset: (PASS)
The device was last self-calibrated on: 12/10/2009 12:11:14 PM
Running Calibration ... FAILED for the following reason:
Error -200545 occurred at DAQmx Self Calibrate.vi:1
Possible reason(s):
Self-calibration failed. The self-calibration date has not changed.
Disconnect the device from external signals, as they might introduce noise. Externally calibrate the device to recalibrate the onboard voltage reference that is used for self-calibration.
