07-11-2019 01:52 PM
Hello, I want to use this card DT9814 in conjunction with LABVIEW, I have installed the NI-DAQMx driver and the LABVIEW program on a laptop without good communication between the card and LABVIEW , according to The procedure to recognize the card is with the help of NI-DAQMx but the device is not recognized, following programs I have:
Laptop: Windows 7 operating system, 32 bits.
Labview: 2017
Ni-DAQMx: Version 8.5
Will you have any correct recommendation or driver?
Thank you
07-15-2019 03:21 AM
This is not a NI board. You probably also need the drivers from MC.
