‎08-04-2017 09:13 AM
I am experiencing an issue with the DAQ Assistant function after installing the NI-DAQmx 17.0.0 driver from NI's website. I also selected "Search for important messages and updates on NI products being installed". There were no notifications that were alerted.
I am using LabVIEW 2017 64-bit (Student and Home edition) on Windows 7.
I have restarted the PC after completing the installation.
When selecting the DAQ Assistant function, the DAQ Assistant wizard is initialized, I then proceed to select the measurement type (Analogue In/Analogue Output, for voltage respectively). The NI modules being used are NI-9264 (AO) and NI-9201 (AI). I proceed through the wizard ensuring that all parameters were selected within the correct range. Upon completion of the DAQ Assistant Wizard there is a long delay (1 minute) and the DAQ Assistant remains un-configurable as shown below.
‎08-04-2017 10:34 AM
I was thinking of uninstalling and reinstalling LabVIEW but was wondering if anyone had a different approach in mind, to save me burning daylight.
‎08-04-2017 10:47 AM
I've taken the "burn daylight" approach, wish me luck. I'll keep you posted if it resolves the issue.
‎08-04-2017 02:04 PM
I've uninstalled LabVIEW & DAQmx and reinstalled. Unfortunately the issue remains unresolved... I think I'll need to raise a ticket with NI.
‎08-05-2017 01:44 PM
I had to uninstall every driver and program associated to LabVIEW and then reinstall.
The DAQ Assistant block is now working.
