Multifunction DAQ
DAQ Analog Input reading unchanged with changing voltage input
Using "Acq One Sample.vi" from NI examples.
Have PCI-6259 DAQ attached to SCB-68.
Have AI 0 (pin 68) attached to V+ of power supply.
Have AI GND (pin 67) attached to V- of power supply.
Applying voltages ranging from 0 to 5 V.
The readout of the VI indicates a constant 3.08xxx V, with flucuation in the thousandths place.
Why am I not getting a true voltage reading?
I have a Fluke DMM connected to the V+/- terminals to monitor the actual output.
The DAQ shows no change in voltage reading regardless of voltage supply setting.
(3,038 Views)
OK,
I'll answer myself.
Nothing wrong with the equipment.
Have two SCB-68 units connected to the PCI-6259 card.
I had the wires connected to the wrong box.
As we say around here, "The error involved the connection between the computer keyboard and ground"
User error.
(3,021 Views)
