Multifunction DAQ
DAQ-6009 unable to use the device in Ubuntu 20.04
Just purchased the NI DAQ-6009 ADC to measure temperature/humidity from a sensor.
After following the installation from here for Ubuntu 20.04, we are having problem to use the device.
Based on document
we are supposed to see /usr/local/natinst/nidaqmxbase/ but we see only /usr/local/natinst/ and subfolders lib64, ni-daqmax, some some .
Is this ADC module supported by ubuntu? or else thanks for giving some troubleshooting hints...
(1,129 Views)
Most USB DAQ except for cDAQ are not supported on Linux.
NI Hardware and Software Operating System Compatibility
While the legacy NI-DAQmx Base might support some USB DAQ, it is not supported on Ubuntu. Archived: NI-DAQmx Base and Linux / OS X Compatibility
https://tmesystems.net/
(1,087 Views)
