Multifunction DAQ
Cvi exe file
Hello I create my application code for an usb 6008 daq. I have my exe file but I want to use in another computer which does not have lab windows installed. Is there a base program that I should install to run in this computer?? I installed the daqmx 9.8 but got an error mising cvi.dll in windows 7. But in xp works fine
(2,877 Views)
Did you also install the CVI runtime? You should post to the LabWindows/CVI board about how to properly create an installer with all of the necessary components. It is NOT enough to simply copy an exe.
(2,869 Views)
