Multifunction DAQ
Crosstalk with BNC 2120, PCI-MIO-16E-4 (6040E), and e57891 cable
I'm measuring some pretty slow signals (on the order of 1 kHz) using the AI acquire multiple waveforms.vi with the default settings (except for the sample rate) and I'm seeing about -9dB crosstalk. I don't think it's in the rest of my setup, since I don't see any problems when I plug my BNC cables into an oscilloscope. I can't seem to find crosstalk specs for any of the parts in the title, but I have a hard time believing that this is strictly a hardware problem. Is there something I'm missing that might be causing this problem?
(3,445 Views)
Here is a great KnowledgeBase discussing Cross-Talk issues, and some different solutions:
http://ae.natinst.com/operations/ae/public.nsf/web/searchinternal/b9bcdfd960c06b9186256a37007490cd?OpenDocument
I hope this helps. Have a Great Day!
George
(3,437 Views)
Thanks for that link.
I fixed my problem, but now I'm wondering why what I did fixed it. Sampling the channels in the other order fixed it, but I don't see any reason why it should. Both of the input devices have identical resistive and capacitive loads, the signals only differ in magnitude by about 50%, and I have the same gain settings for both channels. Is there any other sort of asymmetry that would cause that fix to work? I don't like the idea of using this without really understanding why it's working.
(3,430 Views)
This more than likely has to do with the settling time between channels. I'm glad this worked for you.
Have a Great Day!
George
(3,416 Views)
