Cross talk between two DAQs
Hello Guys,I have a problem if you can help me, it will be much appreciated!!!!
 I am using two different DAQ devices on two different
computers. I am using BNC 2111 (PCI 6221) on one system and USB 6008 on
another. I have connected these two device with T-junction BNC, which means
that the incoming signal (signals are analog from 0 to 10 VDC with BNC
wires) are divided into two at BNC 2111; one goes into BNC2111 and other goes into
USB 6008. I think I am having a cross talk between these two acquisition
devices; when USB 6008 acquire the data I see a little peak in data at BNC 2111. So
to solve this problem I was think to use BNC ground loop isolator available in
the market for video surveillance (these are available from DC to MHz range:
http://www.smarthome.com/70431/Enforcer-In-Line-BNC-Ground-Loop-Isolator-VG-1C12AQ/p.aspx ).
Can you please suggest of what do you think about the problem and solution?
And feel free to suggest any other solution or any other device-type. I will
really appreciate it.
Thankyou and thanks for reading thisSmiley Happy
(3,526 Views)
Take a look a this document regarding reducing cross talk in BNC connector blocks, it gives some good suggestions for reducing the effects you're seeing.
(3,498 Views)
